GregShelton
Hi everyone,
I recently went on an excursion into the world of papier-mache after having discovered that it has been used to make boxes and even furniture in the past. I have played about with the material and I have been pretty astounded by the results (much better than you might think for it's all its primary school art class reputation!). The one thing I found out was that the most important part of creating a project with smooth professional finish was the application of a finishing, sealer coat of gesso.
I didn't even know what gesso was, so I had a look online and straightaway I was directed to homemade alternatives. I tried a few recipes but the one that has worked the best, producing a strong and solid coat with great adhesion and sanding properties, is this (I forget the quantities) : PVA glue, acrylic paint, talcum powder and water.
After having read a little on finishing, I saw that gesso can be applied to wood so I tried and was very happy with the results when I used it to seal a piece of MDF for lacquering with an alkyd urethane-based black lacquer varnish.
There don't seem to be any problems with adhesion at the moment but are there any pitfalls to this gesso recipe? Will it crack, fall off or interfere with the lacquer layer in some way later down the line? Will I get dots or bubbles of some sort due to the composition of the talc, paint or glue?
Thank you!
Thank you!
