TrimTheKing":23qawptr said:
There's no surprise she can't see much difference between TV and DVD, composite is destroying the picture quality of the DVD and briging it right down.
I cannot understand it because it does not sound that bad for an old system, and not that I have really ever sat down and watched it for more then a couple of minutes, the picture is fairly good :duno: But as you say if the dvd quality is not to good or at least the same as the TV then that is probably why she does not see any quality issues.
Ignore this now based on what we know about the connectivity.
Mike.C":23qawptr said:
She does not watch terrestrial tv, or not really as she watches everything on sky through the AV channel, would that make any difference?
If she is only watching TV through AV then she is watching it through SCART and getting the best possible video out of the system.
I had a quick look behind her tv and she has a scart running from the sky box to the tv and then one from the dvd to the tv, and the only other wires are the 6 sets running from the speakers to the dvd.
I'm really quite confused about this now Mike. If the below is what she has then I have summarised under that what she will be seeing/hearing.
SKY-TV = SCART
DVD-TV = SCART
DVD-SPEAKERS
So, with this in mind what she will be getting is this
Watching DVD
- Video sent to TV via SCART (best possible she can achieve with this system)
- Audio sent directly from DVD system out of speakers, will be full 5.1 (best possible she can achieve with this system)
Watching TV
- Video sent from Sky to TV via SCART (best possible she can achieve with this system)
- Audio??? With no connectivity from the Sky to the DVD system then I cannot see how the sound can come out of the system speakers! Are you sure she isn't just getting the Sky audio out of the TV speakers only?
The only other way I can see that the Sky audio could come out of the system is if the SCARTs on the TV and system are 2 way communication and passing the audio from the Sky to the system, but I'm not sure whether or not that is how SCART works.
So whether she gets the Sony or Panasonic mentioned above what leads does she need to buy to get fell digital audio
To answer this one first, if she buys either the SONY or the Panasonic then to get the best out of it she needs to connect it as follows (and this is based on not be able to find any reference to absolutely confirm that the SCART on the SONY/Panasonic's are I/O or just output so might differ if they are I/O. The SONY states on the diagrams that the SCART is 'Output to TV' so this would indicate single way transmission, but one of the diagrams in the manual suggests that if you connect all devices to the TV via SCART then you will get the Sky sound through the system, so they must be 2 way in that case.)
SONY-TV = HDMI (For DVD/Sky output to TV)
SONY-TV = AV1 SCART (For receiving Video from Sky through TV)
Sky-TV = AV2 SCART (For sending video to TV from Sky)
Sky-SONY = Optical fibre cable (For digital sound from Sky box. SCART only passes 2 channel).
and does she need a HDMI cable just in case she updates to skyhd?
If you set it up as above, then get SkyHD she will need a second HDMI between SkyHD and TV as there is no HDMI input though the system.
If she does get the skyhd box will she need any extra leads?
Only as above. The optical cable will just shift between Sky boxes.
And finally will she be watching and hearing full hd through either of the above systems?
SkyHD is 1080i, not 1080P (true 'full' HD, but she will be as close as you can be with SkyHD).
I realise that unless she buys a bluray player/system the best she can hope for is upscaling to 1080, but can she add a bluray to either of these systems at a later date?
Yes, but there is only a single digital input for audio on these systems so she would either have to buy some kind of fibre switch box to allow 2 inputs to a single output, or switch the optical cable between SkyHD/BluRay when changing devices.
Sorry if all that is a bit or a ramble, but hopefully it will make sense. You have my number if you want to talk it through.
Mark
