busy builder
I have just purchased a Startrite 352 and I'm attempting to adjust the blade guides.
I can adjust the top ones to within 1 -2 mm of the blade, but I cannot fathom out how to get the guide (discs) behind the blade teeth as stated in the handbook.
On the bottom guides I am attempting to adjust the guides to almost touch the blade, as shown in the book, by undoing the lock nut and turning the allen bolt from the top. Well I can undo the lock nut and turn the allen bolt but nothing seems to be happening to the guides, which are also on the teeth.
The blade is as supplied 12mm 7tpi and is in the middle of the crown on the top wheel, which I assume is where it's supposed to be ??
Thanks, Andrew
Thanks, Andrew
