Hope some of you might be able to help with this. I have a Camvac 386 90L triple motor camvac with the old style cyclone which was a separate bin.
All seemed to work fine initially and when I look inside the cyclone bin it's accumulating the chips and dust and inside the extractor bin there's very little. The problem is this: after hardly any time at all - ie a couple of hours of cutting plastic on the bandsaw I have a clogged filter bag in my extractor and when I look at the pipe going from the cyclone to the extractor I can see fine dust being sucked up the outlet pipe.
I thought it was just that the cyclone bin was too full initially so cleaned it all out but low and behold, after another 2 hours it's clogged again and the same thing is happening.
I can't afford to have this happening all the time. It's a pain to empty, I have to shake out and wash the bags and the inner paper filters also get dusty so theoretically they need replacing each time. It's only 2 hours!
I took some photos tonight after the same thing has happened again and there's not that much in the cyclone bin really. It's a big bin.
Hopefully some of you may have ideas as to how I can sort it out:
Is it:
a) I'm cutting plastic so the dust is fine anyway given I make miniature stuff and it's a 8/10 blade on the bandsaw so the dust is too fine to drop
b) It's a poorly designed cyclone and it was never going to work anyway
c) It's not a great design but I can do 'X' to sort it out
Hope someone can help.
Thanks all,
Jennifer
Is it:
Thanks all,
Jennifer
