Good Surname or what ?
My HMS2600ci has just packed up while I was in the middle of thicknessing a batch of components.
Symptom:
When in thicknessing mode with no load the rollers and block are turning fine. When I feed the workpiece through it catches and is pulled forward but stops abruptly and the machine makes a loud whirr/clicking noise. If I stop the machine and start again without a load it spins fine but stops the same way a few seconds after I feed a workpiece.
I have removed both side covers and operated the machine. When it stops the chain drive for the rollers stops but the block is still spinning (I think - might have to check that again)
Any thoughts?
cheers
Phil
Symptom:
Any thoughts?
cheers
Phil
