Philly
HI Folks
I've had a good few years of use from my Xcaliber 806 10 inch table saw (a Delta Unisaw clone). Today, after making a few cuts, it failed to start. It makes a humming noise and the blade fails to turn. I've checked the blade turns freely (which it does) and there seems to be no obvious physical problem.
After a quick call to Woodford, they suggested it was either the condenser on the motor or possibly the switch playing up. I've just checked and the humming noise is coming from the area of the motor not the switch.
So - any suggestions? Is the condenser an easy part to replace? Do I need to get a sparky to check it out first?
Philly
Philly
