Hi Hope someome could help suggest a way to get this part removed from a motor shaft.
The motor i am recucling for a project but it has a speed reducer box of cast iron on the motor spindle. I dont want the gear /reducer part just the motor. Though dont want to dame the gear as they are pretty procey units. The front flange of the gear box and some sort of sleeve gear is attached to the motor spindle by a keyway only ,i cant find or see any other fastening which would stop it coming off.
I cant use a bearing puller as i cant access the end of the actual motor shaft and the flange plate from the gear box is also free on the spindle and in the way.
See photos ad hope someone could suggest something.
Thanks Bob
Thanks Bob
