Phil Pascoe
It's a Bosch GST 85 PBE. I have voltage at the switch, but when I depress the switch and test the other "live" terminal I have nothing. I'd have thought there should be a reading there?
He has power at the switch Pete so it's getting through though, on second thoughts there could be a break in the neutral. More thoughts.... he isn't getting power on the out side (load) of the switch.Pete Maddex":3p9jd095 said:Usually a break in the mains lead with power tools, try pulling the wires that go into the mains lead with the cable clamp released, I bet one will pull out.
Peter
Pete Maddex":33ianp45 said:Usually a break in the mains lead with power tools, try pulling the wires that go into the mains lead with the cable clamp released, I bet one will pull out.
Peter
