shim20":1hwwjgt4 said:
MickCheese":1hwwjgt4 said:
everyone says good things about the ls1013
I don't and I know many other contractors that don't.
I own both the LS1013 and LS1214. They are both s**te!
They aren't built to be site saws and both have exactly the same problems. The first thing that breaks is the trigger, second is the slide lever, next up is both hold and turn rods give up and don't do as they should, the guards don't lift after a while, and the degree settings on both machines are miles out and are generally pretty rubbish at anything that needs a degree of accuracy.
I had enough of the 1013 a few weeks ago and just threw it into a skip that was on site. If money wasn't so tight, the 1214 would have gone it as well.
