bogmonster
Hi,
Finally decided to bite the bullet and replace the bearings on my lathe. Not very experienced at this kind of work so wanted some advice before I screw it up The shaft is out and the bearings are off the shaft. Had to dress the shaft where the spindle lock goes but as there was a bur but that was easy. Disassembly was all very easy with bits of tube, vice, wooden block, mallet. Now for the bits I am unsure about....
The front and rear bearings are tapered roller bearings. The outer shells are in the casting of the headstock. There is only the smallest of rims on the inside and no obvious knock out points for a punch. I probably can get a punch on it but is there a special tool for this job?
EDIT: The outer shells are now out. Used a punch and the came out easily. Just stuck the the middle bearing now. Good news is it is small so I can take it to a man who can if I get stuck.
Also, there is a third bearing that is a standard sealed ball race. This is part of the speed control. I have got the outer section removed and the bearing came away with the outer and thus I have a similar issue.
I guess I could make a tool but sounds like heavy lifting for what I am sure is a common problem.
On reassembly I guess pack bearing with grease. How do I know how tight for the bolt that pulls it all together? Obviously if the shaft gets stiff to turn then that is bad. If the shaft has play that is bad. Is that it?
Cheers, BM
Cheers, BM
