You certainly can use a scroll saw whilst sitting and I should say most of us do.
As for what you can make with a scroll saw... it's a bit like asking what can you cook with an oven
. Really, the only limitation is your own imagination. I'd like to show you some of my work as examples, but my online picture hosting website is currently undergoing maintenance
A lot of scrollers like to translate photographs into wood by creating shadow portraits. This is achieved by converting the picture into a mono-tone pattern (black and white - no grey
) which can then be cut with a scroll saw. This is quite straight forward since all scroll saws allow you to cut whilst turning the wood and the thin blades can be inserted into drilled pilot holes in the middle of a board. However, just because it is straight forward it is not necessarily easy - some shadow portraits are terribly detailed and delicate. Yet some are beautiful because of their very simplicity.
Some people embellish furniture with decorative details, some make whole pieces of furniture or small trinkets. It's possible to inlay wood and other materials with a scroll saw, you can make clocks and similar mechanical devices, you can even make wooden bowls without using a lathe. It's possible to make jigsaws which can be designed to amuse by incorporating suitably shaped pieces, such as reindeer-shaped pieces for a Christmas pattern. You can make your own Christmas decorations too, which is a favourite of mine. Then there are door signs you can make, Welsh love spoons, children's toys... the list goes on.
If you're familiar with lathes, scroll saws can be used to create some very attractive and distinctive pen blanks too.
I'm sure I've missed dozens of other uses for a scroll saw and I've no doubt other members will chime in helpfully with their ideas.
