Hi All,
Whilst doing some DIY I recently discovered my grandfathers old shed and some of the tools slowly rusting away there and immediately started renovating them using some of the advice found on these forums. I have now also managed to find an old Stanley Bailey no4 at a car boot which was in fairly good condition except for some light rust. I have been cleaning this up with scotch pads, various cleaning solutions such as Hammerite and Restore Rust Remover and judicious amounts of elbow grease. Most of the metal has been cleaned up and oiled. This is all being done with a view to the tools being working implements so durability and functionality is more important than shine.
I have read various postings here about the subject of renovating hand planes but still had a few questions.
1. The tote and knob had some sort of coating on that was flaking horribly. I have sanded these down back to the wood and now need to coat them in something to protect them. I have seen some mention of linseed oil for wood restoration. Some people talk of shellac or clear varnish. Some mention waxes of various sorts. What would be a suitable substance to put on the knob and tote to give it good use and environment protection? If possible I would like whatever I use to leave the wood looking its natural colour as I quite like its current look.
2. After reading some discussions about repainting old hand planes I was a little unclear on whether it was an aesthetic thing or if it added to the planes durability. I quite like the look of the metal now it has been cleaned down and am not fussed about recoating in something like engine enamel (which I saw discussed somewhere). However I am unclear whether the painting in engine enamel aids protection against the elements if so perhaps I should do it to prolong the life of the plane? Or would it be ok being cleaned down and rubbed with 3in1 oil?
3. I see discussions online about bevel up or bevel down planes. Is a plane designed to be one or the other? If so which should my stanley bailey no4 be? (In my eagerness to start renovating I took it apart but didnt note which way up the blade was, oops.)
4. I have read many articles and watched many videos (I find Paul Sellers particularly interesting) on sharpening the tips of blades. But not much mention on what, if anything, to do with the underside of the blade. For example in one of Paul Sellers videos he talks through sharpening the tip but says he doesnt have to spend too much time on the underside of a blade when sharpening as he always "polishes" his blades when he first gets them. Is the "polishing" processes the same as the sharpening, slowly working the flat back of the blade on various grits of wet and dry?
Any advice at all about my questions or the renovation in general greatly appreciated.
thanks
Gebbly
thanks
Gebbly
