Any one use a rail square fitted to a guide rail?
Clive.
Clive.
I first use the parallel guides to cut the sheet and then the benchdogs rail square to square the ends / cut to required length. On smaller items I just use the rail square making sure I work of the clean face, even with a parallelogram there is no reason not to end up square.I’ve got the benchdogs one with the additional fence and stop. Works well but I prefer parallel guides
Squaring the end after ‘ripping’ to width is why I got mine. Though once I have squared one end I find I shift back to the parallel guide referenced from that squared edge.I first use the parallel guides to cut the sheet and then the benchdogs rail square to square the ends / cut to required length. On smaller items I just use the rail square making sure I work of the clean face, even with a parallelogram there is no reason not to end up square.
