LuptonM
Can anyone advise me how I might grind plane irons on a dry bench grinder so the blade is straight and square ready for honing?
What is the problem exactly?LuptonM":17b1m068 said:Can anyone advise me how I might grind plane irons on a dry bench grinder so the blade is straight and square ready for honing?
True no doubt, but for a practical working/sharpening regime, accuracy and repeatability are not priorities.OPJ":m0u43wr3 said:Do you have a table or tool rest with your grinder? Something like this. That's one of the easiest ways to get accurate and repeatable results.
OPJ":1zv6y0ml said:Do you have a table or tool rest with your grinder? Something like this. That's one of the easiest ways to get accurate and repeatable results.
Car boot stuff I usually start by honing at 30º (same as what crazy sharpeners might call "applying a 30º micro secondary bevel") just to see how it comes out. If the blade was already in good nick then that's it, all you need.LuptonM":3ridm33l said:.....
So basically I want a reliable way of grinding chisels and plane irons straight and if I want to add chamfer to the blades I can choose to do that myself....
LuptonM":1o2qhh8b said:..it adds quite a large chamfer to the blade
Or just draw a line with a felt tip pen.bugbear":3fwpg0qe said:LuptonM":3fwpg0qe said:..it adds quite a large chamfer to the blade
I think you've become confused. You're using "chamfer" to mean "camber".
They're not the same thing at all.
Moving on...
Grinding a straight and square edge is fairly easy. Just mark a line on the blade, and work to it. Since metal is removed slowly (even with a power grinder) it's easy to be accurate.
To mark the blade, either use a carbide scribe, and make a scratch, or coat the blade in engineer's layout blue (or marker pen...) and use "anything pointy"
BugBear
Paul Chapman":2cq7oqmo said:I'd persevere with the wet grinder if I were you - it's so easy to burn and ruin blades on high-speed grinders. Many people seem to complain that wet grinders are slow but I find mine (a Tormek) is fast. Are you pressing hard enough?
Cheers :wink:
Paul
hand grinder is seriously cool but I bet its slow (though maybe not as slow as my wetstone grinder-it turns 90rpm)Alf":2cq7oqmo said:I use the Veritas tool rest - works okay. Wouldn't bother with the jig; better to use your eyes to see where you need to grind than blindly follow the jig, in my experience. (Embarrassing and ancient YouTube vid here, if it helps. Pardon the parrot.) Also you need to keep a light touch on the wheel to avoid over-heating, and the jig in the track just stops one easily removing the steel from the wheel. Nice in theory, not so good in practice.
Mr G Rimsdale":1i5akn51 said:Or just draw a line with a felt tip pen.Bugbear":1i5akn51 said:To mark the blade, either use a carbide scribe, and make a scratch, or coat the blade in engineer's layout blue (or marker pen...) and use "anything pointy"
BugBear
LuptonM":2mxydoeu said:Have u tried the veritas tool rest (and maybe the jig that goes with it)?
Sure can, and much better than a grind-wheel; flat bevel, runs cooler, wider than any plane iron. I grind with 60 grit.LuptonM":2ru570j2 said:To save me buying something do u think I could use a hand held belt sander in some way (maybe mounted upside down) to grind tools?
Mr G Rimsdale":d5l687u7 said:Sure can, and much better than a grind-wheel; flat bevel, runs cooler, wider than any plane iron. I grind with 60 grit.LuptonM":d5l687u7 said:To save me buying something do u think I could use a hand held belt sander in some way (maybe mounted upside down) to grind tools?
Also you can use it for sanding wood!
I've got a bench grinder and an angle grinder but they are for metal work, not for sharpening - except spindle profiles.
Some of them come with brackets so you can turn them upside down or hold them in a bench vice. If not then it's not difficult to make something up. I've got the posh Bosch which sits upside down quite easily, but has brackets too, for horizontal and vertical mounting. That Clarke looks a big bu***er maybe more than you need, but I don't know anything about it.LuptonM":1wxd3opp said:....
The problem with my idea is how to hold it upside down and stop it moving
Abso bloody lutely! Don't buy anything!..
For a noobie, when it comes to buying equipment its like a jungle out there. Companies are always making u want something u'll never need
Er - except you don't need any equipment for honing (except an oil stone). We all get taken in at some point by the sales pitches!At least I think I got my honing equipment right the first time
