sihollies
Hi all, I was wondering if anyone could please advise?
Bit of a random enquiry, and I hope it is in the correct topic forum.
I am planning to make several personalised Christmas cards using 2 pairs of veneers to act as the front and back of the card, with a fabric or wide ribbon glued between the leaves to act as the hinge.
If I am successful, I will then transfer personalised photos & messages onto each card.
I am a hobbyist and mainly use veneers in the projects I make, so have a little bit of experience how they may react, and I know that the veneers may curl when glued.
my thought to remedy this is that I should run the grain perpendicular to the other to prevent this happening?? (Similar to plywood, but only 2 ply as I don't want the cards too thick)
I would normally use PVA when glueing veneer to a substrate, & know that the veneer will start to curl when the PVA is applied.
Would a contact adhesive be better in this situation?
I was also wondering if veneer softener may help to stop them curling??
I hope I made the above as clear as possible???
Many thanks in advance
Simon
Simon
