Dieseldog
Im sure is has been asked before but what Glue would you recommed for the brass tubes when pen making ?
Thanks Dave
Thanks Dave
Jonzjob":10avwq3e said:Neil said "Also what a hassle keying the tubes every time"
All I do for thayt is to put them, 2 by 2, on the mandril and spin it up and a quick wipe with some 120 abrasive. Dead easy and very quick.
jumps":1z837i54 said:.....In this case the recommended drills were 0.5mm larger in diameter than the tubes; this seems to provide a little more clearance than I would expect. .......What do others think?
CHJ":1jdp956v said:jumps":1jdp956v said:.....In this case the recommended drills were 0.5mm larger in diameter than the tubes; this seems to provide a little more clearance than I would expect. .......What do others think?
Depends a lot on the kit profile and how thick the 'blank' walls are on the finished item I guess. A clearance of .5mm could leave some very thin material walls on the kits I've used if the tube was not centralized, I've even selected drills to within .1 or.2 mm at times..
Would certainly want to make sure that the drill was cutting true to size with that amount of slack.
jumps":2fhu8d2t said:I was going to start a new thread but it's so related to the glue you intend to use that I thought I would post here.
Prompted by a couple of reviews on the Ax site to a kit I am currently playing with (I got 3) which referenced the recommended drill sizes.
In this case the recommended drills were 0.5mm larger in diameter than the tubes; this seems to provide a little more clearance than I would expect. It certainly rules out CA glue!
Neil Farrer":w37oy1i0 said:.... I am at a loss to work out why some distributors either change the manufacturers recommendations or recommend a metric measurement so far from that needed that it will probably spell disaster for the turner. ......My opinion, for what its worth is use the correct size, always, it doesn't pay to compromise.
Neil Farrer":lgrlkal9 said:jumps":lgrlkal9 said:I was going to start a new thread but it's so related to the glue you intend to use that I thought I would post here.
I suspect that one of the reviews that you might have read may well have been mine. I am at a loss to work out why some distributors either change the manufacturers recommendations or recommend a metric measurement so far from that needed that it will probably spell disaster for the turner. If the tube size needs a 37/64 drill bit then there's only one drill bit to use, a 37/64. One distributor selling the same kit as Ax actually recommends using a 14.5mm drill bit. Clever one that, by my calculation the tube (which actually requires a 37/64 drill bit) is larger than 14.5mm! DOH. A 15mm drill bit is too big, the overall finished dim of this pen is 16.6mm I think from memory. When put in perspective, if you use a 15mm drill, you've got two walls at 0.8mm with a glue thickness of 0.2mm twice. If thin the worse case scenario, after turning it you may have one side wall at 1mm and the other at 0.6mm. If you use the correct drill bit then you should be guaranteed that the wood is located evenly around the wood and you have a better chance of the best adhesion possible. Using the correct drill bit will leave you with two walls of 1mm thick each.
I haven't had a problem sourcing imperial drill bits for pens and at very reasonable prices. In fact I can get the imperial drill bits easier than I can metric. The engineering world still works in imperial and with the exception of the 37/64 drill bit I can get all the others from three sources within two miles of my house, nearer than B and Q Wickes, Screw fix etc etc.
The 37/64 are there to be found TR sell them as the Gentlemens drills I think. Very expensive but you can get them mail order by asking Mr Google a lot cheaper.
Register today and take advantage of membership benefits.
