artie
Sawdust manufacturer.
It appears to me in very simple terms.
If you have a solid object and the air around it is 4-5 deg C higher than said object you are likely to get condensation on it. The amount of which is dependent on the humidity of the air.
If you can put a barrier between the air and the object so that the air to barrier temp difference is 2-2.5 deg C and the temp difference from barrier to object is 2-2.5 deg C then you will have no condensation, hence the popularity of insulation.
If on the other hand, you brought the solid object temp up to within a couple of degrees C of the air, there would be no condensation.
Anything wrong so far.?
