GemRed gauge woes!
Eric The Viking
19 Jan 2010
One of my Christmas* presents arrived yesterday: a GemRed digital angle gauge, promptly delivered from D+M in Twickenham:
It looks a useful bit of kit, but I'm regretting spending extra on the version with the spirit level. I can't adjust it properly, and it seems to be completely useless. There are three issues I can see:
1. As manufactured, the plastic vial has stress fractures and will eventually break (it arrived screwed down very tightly).
2. The vial is cylindrical internally -- adjustment is thus impossible.
3. The vial and the liquid inside is highly insulating and static sensitive. in this cold, dry weather, wiping a finger very lightly over the surface causes the bubble to move.
Issue #2 is the worst, obviously, putting it into the chocolate teacup department. It's a 'building spirit levels 101' class of mistake one wouldn't expect. I don't mind it being 'off' as-delivered, but un-adjustable is pretty poor.
If I'd known, I wouldn't have bothered with it as an add-on. It's not its primary purpose, but would have made it much more useful for a range of jobs (setting out DIY stuff, for example). Actually, I could even have stuck an adjustable bubble on the flat top of the ordinary version!
I'm in two minds whether to send it back or not. It isn't D+M's fault, obviously, but does it fall into the 'they all do that, sir' category?
Does the team think they all come from the same (Chinese) melting pot, or is the Wixey one (for example) better?
Thoughts appreciated...
E.
PS: If the bubble is that poor, should I trust the inclinometer bit, either?
*I'm actually spending a present - Santa wasn't a month or so late!
Mcluma":1k66dscc said:
send that one back
wixey does a new one, with a build in digital level working on gravity
I think you're right.
On the notes on the Wixey web site (I assume GemRed is a copy), they say the level divisions are 3 arc-secs. That would be fine - the bubble is too small to be really accurate (it's not the length of the spirit level but the length of the vial that matters).
I couldn't see a ref to the new one - do you have an URL?
Cheers,
E.
