The Weegie
Hi there,
i have been asked to install a basic cabinet around a fuse box for a friend. The fuse box is on the wall above an internal door right underneath the stairs :x The right hand side of the cabinet would need to be cut at an angle to accomodate the slope from the stairs.
Apologises but no pictures.
Dimensions are approx 21" in height by 38" in Length and 8" in depth.
I have been thinking about options for this for a couple of days now.
I intially was going to build a frame from 18mm mdf and 2 18mm doors using flush hinges. I was then concerned about the weight of this.
I then thought about 12mm MDF using these
http://cdn.toolstation.com/images/13012 ... /13965.jpg
Wasn't sure that 12mm would be thick enough for these hinges.
Any ideas as to the best way to approach this.
