Sawdust=manglitter
Not done much in the workshop over the last couple of days due to the weather. Its the first time since i’ve had the workshop that the temperature has gone into the negatives. The themometer says the minimum temp its been is -1.1 degrees. The workshop is currently +1.0 degrees, i took the cover off and went to use the tormek, and the wheel has ice crystals over it...
I want to avoid cracking the wheel at all costs, so do i avoid using it until it naturally de-frosts?
