Follow the Bouncing Ball
Yep, works fine on Google Sketchup. Very clever, Dave =D>
Cheers,
Neil
Thanks Neil.
Although that illustration isn't woodworking related, the same idea could be applied to opening doors or raising table leaves or any number of things along those lines.
I think I still have a model I did for a table that has leaves that slide in underneath the top when the top is lifted. There's a name for that sort of table but I can't think of it right now. In anycase, I animated the leaves being pulled out as a way of confirming that I had the geometry correct. The table itself wasn't anything more than basic parts but I could take that and create a table design that I'd build.
This could be used to check for conflicts between moving parts or to illustrate the order of assembly of a complex piece.
