Fluorescent fittings
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
I installed a fluorescent light in the loft last year. Makes a great difference. Or I should say, made. I went up to get something recently and it doesn't work. Just a faint glow at one end. I've changed the starter. but no joy. This has been on for just a few minutes in its miserable little life. Anyone know what could be wrong. Have I just got a duff one or is there something about the environment (it's cold up there) that would affect it? I don't want to replace it with another if the same thing is going to happen again.
Any ideas please?
Steve
DaveL
19 Oct 2002
Sudbury, Suffolk
Steve,
The cold does affect fluorscents. :(
That glow is a heater that the starter runs when its first turned on, there is normally one in each end. Once the tube has been heated for a short time the starter should cut the feed to the heaters and try to strike the discharge in the tube, if the discharge stops the heaters should get another pulse and the tube then restrikes. 8)
Well thats how it should work. :shock:
I don't know how cold it is where you are but I have not had any problem with the cold in my shop yet this year. It could be that one of the heaters in your tube has blown, or the wire has fell off in the fitting, or as its in the loft you have a family of spiders taken up residents and disconnected something in the process.
I would, with the aid of another light, take the tube out and turn it round and try it again. If it doesn't work things the check.
Glows only at the same end of the fitting, wire off in the fitting.
Glow now at other end of fitting, dud tube.
Don't fall while balancing on piles of stored treasure in the loft. :roll: :wink:
A
Anonymous
Guest
Steve
Cold of that level should not affect very much althoughn damp willl. You may have a duff tube or duff choke. The choke stores energy while the heaters are exciting gas near them until the starter opens the circuit, thus causing the choke to discharge through the gas in the tube. The excited gas glows and emits UV light. The powder on the inside of the tube glows white when hit by this UV
I suspect starter or tube - if it is the choke, then you may struggle to get one
As you have changed the starter, then it is probably the tube.
Chris Knight
14 Jan 2004
SE London - NW Kent
Steve,
I had a spate of starters and tubes going in my shop. It started with a number that had been installed at the same time going down within a couple of weeks of each other after several years service (very accurate built-in obsolesence timers!) so they also got replaced at more or less the same time with stuff from the local Focus shed.
These died in short order (a couple of weeks) and to cut a long story short it was both starters and tubes that were to blame. I now get my stuff from a decent electrical trade supplier and it works much better!
Losos
24 Aug 2004
West Suffolk
Chris - Who are your 'decent electrical suppliers'? Also, does anyone use lights with electronic ballasts? In FWW they often discuss lighting and some users seem to prefer the electronic ballasts. I think most of the cheaper fluorescents use a transformer type ballast but I'm not certain.
A
Anonymous
Guest
The original type of flourescent used a choke - similar to one coil of a transformer and cheap modern flouros still do.
There will be very little advantage in using an electronic ballast, particularly in a loft where the light is seldom used
Chris Knight
14 Jan 2004
SE London - NW Kent
Losos,
Just a small local firm - no internet presence. They sell what seems to be decent gear- it looks better and costs more but seems to last a lot longer. I am no electrical expert and have accepted what they tell me about the quality differences between their gear and Focus stuff - maybe naive but I have had no cause to doubt them.
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
I went up in the loft again today and tried the turn-the-tube-around-thing-trick. The glow moved to the other end, so, on the assumption that Dave is right :D , I'll get another tube next time I'm out. It's very annoying to have one go after so little use, but better than having to change the entire fitting, I guess.
Thanks to all for your input.
Steve
Losos
24 Aug 2004
West Suffolk
Tony / Chris - Thanks for your input also I won't bother getting electronic ballast fittings - probably hard to get in CZ anyway :(
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
Crimbo over, decoration box back in the loft, along with a new tube, and hey presto, we have light!
Thank you all for your input.
Steve
