I flatten my waterstones on floatglass with SiC powder. The glass is
protected with mylar/polyester sheet. Sic powder is IMO just too hard and
It breaks down very quickly. I am looking for a loose abrasive that is fast and doesn't
break so quickly.
I am using 120 and 220 grit sic powder. After a few seconds the SiC
becomes much finer. Sometimes I also notice tiny black spots in my
waterstones which I am sure about is SiC particles. SiC is super hard,
9.3 on Mohs scale. I think because of the extreme hardness, the SiC
not only abrades, but also cuts in the waterstone and can get stuck.
I use practically no pressure, so I am not pressing the SiC in the stones.
I was googling for a softer abrasive. Found aluminium oxide which
is only slighlty ''softer'', 9 on Mohs scale. Too hard. Zirconia would be good
at 7.5 mohs scale. I have used Zirconia belts in the past and they
lasted a long time. Unfortunately I could not find zirconia abrasive
powder. I think the loose abrasive is also very expensive, but don't
know.
Sand has a hardness of 7 Mohs scale. It is about 5-6 times softer than
SiC. I know that Egyptians about 5000 years ago used sand as abrasive,
but I wonder if it would flatten waterstones. I am pretty sure sand will
do it, but it has to be reasonably fast.
Anybody tried this with sand? Would it matter if it were beach sand or
mason sand?
I have used wet and dry on glass and I did not like it. PSA 3m paper
is much better, but pretty expensive. Loose abrasive works, but I need
something less hard than Sic for the aforementioned reasons.
Thanks.
Ali27
break so quickly.
know.
mason sand?
Thanks.
Ali27
