Hi all
In the process of trying to fit an Axminster aftermarket fence to a Scheppach TISA 5 tin top I am looking for either 8mm square nuts that are 16mm across flats or 5/16 UNC square nuts that are I believe are mostly 16mm AF, most 8mm nuts are only 13mm AF. They fit into the slot in the ali guide rail so as it can be attached to an ali angle I have fitted to this saw table.
Anyone any idea where I can source some, and if UNC then some lobed knobs with 25 to 30mm male threads?
If only they had used std profile ali extrusions then the slot nuts are readily available!!
