sometimewoodworker
I've just got my first new plane. It is a Stanley 1-12-060 and I suspect that it might need a little modification.
Here are a couple of Pics that show what seems to need a bit of fettling.
When the blade is in a working position it seems to extend an excessive amount. Also the adjustable mouth is as far forward as it can go in this pic.
If that is the case then I will get to work with a file etc.
If indeed the sole at the point that the blade projects is too thick a picture or 2 would be helpful.
I do know that the blade can use a bit of TLC.
The second question is the sole. I thought that plane soles should be smooth, this isn't as you can see here.
Does the sole need smoothing? Or will it be just as good as it is?
