mind_the_goat
We have some rework to do in our kitchen and the boss wants a solid oak cabinet to fit under our new (new to us) full size ceramic sink. The sink will sit on top of a low cabinet rather then sunk into the worktop. I intend to get someone to do the fitting as there is other work to do, but would like to try building the cabinet myself.
I am thinking that the best route is to use biscuits, both to make up the panels from thinner planks and to align the sides, using pocket screws to hold it together. I don't have a biscuit jointer. Is this a good approach?
If so should I buy a low to mid range biscuit jointer or would a biscuit cutter on a router work sufficiently well? Not sure how I would align the cuts in the sides of the panels with a router.
An alternative would be dowels, but I think I'd also need a jig for those.
I suspect a better, easier and cheap alternative would be to put a face frame on an MDF cabinet, but have a feeling I'll be overruled on that idea.
