Gman
Hi everyone.
I have this dream to build at least one electric guitar.
For once, I am trying to do some planning before I get stuck - I know that's a novel idea to many, but there you are.
It's going to be a solid body of hard maple - about 35mm thick. I have the blanks glued up. The front will be veneer of birds eye maple - purchased from a great guy on ebay.
What I want to know is the best way to glue it on - I intend for the body to be slightly sculptured before applying the veneer, and I don't have access to a vacuum press. I am thinking about leaving the edges square and then rounding them over with a router after applying the veneer.
The second burning question is how to finish the beast? I am conscious that it needs to be robust as the veneer edge is likely to be fragile. I also want a semi gloss clear finish that will allow the beauty of the veneer to show through, and it will have to be applied by brush. I have used acrylic in the past, and like it's clarity, but feel it's a bit too glossy.
Any comments/advice/warning of possible pitfalls would be highly welcome.
Thanks in advance
Denis
Thanks in advance
Denis
