finish on top of finishing oil?
Keenedge
17 Jun 2009
Bucks.
Hi, I've just put 3 layers of fininshing oil on an oak framed mirror and was wondering if I should put anything more on top of that or would it be best to leave it at that?
John
John
Really that's a question for you to answer - does it need it?
You could give the frame a rub over with steel wool and give it a coat of wax - that'll give it a nice sheen. But if you are happy with how it looks then you're done!
Philly :D
Philly":354at6pd said:
John
Philly :D
Steel wool on oak? I thought that was a bit of a no no? Mind you I am really only paddling in the sea of knowledge at the moment! :)
miles_hot":25bcz9ui said:
Philly":25bcz9ui said:
John
Philly :D
yep its not a good idea - the iron reacts with the tannins to darken the piece - or sometimes to just give black flecks - that said its possible the 3 coats of oil would stop that happening.
Apologies - I meant the synthetic stuff (which I still can't remember the name of!)
Mind you - if there are three coats of finish on the oak, a light de-nib with steel wool isn't going to touch the oak.
Philly :D
Pan scrubber it is, that will put it out of use for dishes:) Thanks, 2 birds with one thingy.
