RogerS
Following on from the thread on Polyvine, I took a small piece of BEM with similar figuring across its width. Sanded down to 180 grit. Five different finishes applied...from left to right
Fiddes shellac sealer
Fiddes White Polish
Smith & Rodger Transparent White Polish
Smith & Rodger Vitapol Polish
Polyvine Gloss finish
The middle three were variously recommended to me as having the lest colouring effect on the wood as they contained bleached shellac. I leave it to you to decide whether or not these claims are true.
The following series of photographs attempts to show the results after different coats have been applied. In hindsight, if I had the kit, I'd have set up a lit photoshoot booth so that the light angle, level and colour temperature were the same. That would let you see the change in colour as the coats were built-up on each finish. Nevertheless, you can draw comparisons across the finishes on each sample.
First photo is after one coat.
Next photo is after the first coat was knocked back with 240 grit and then a second coat applied.
Third photo is after another coat
Fourth photo is after the fourth coat.
This final photo is after the fourth coat was knocked back with 400 grit, a wipe of fresh finish applied using a clean French Polishing rubber followed by using Liberon Burnishing Cream.
The surprise is that normal Shellac Sealer has less of a colouring effect on the BEM than the other allegedly 'uncolouring' shellac based products. But this is at the expense of losing out on the figuring as I think in the middle three that the Birds Eye really comes out and hits you. The Polyvine (being aqueous based) also has least colouring effect but again lacks that 'punch'.
The Polyvine is aso pretty awkward to apply as well as being bloody expensive. It is very gloopy and does not flow at all well leaving brush marks behind (synthetic brush) so you do have to knock it back and then apply the Burnishing Cream. Diluting it slightly does improve the flow however.
Fiddes White Polish
