A
Anonymous
Guest
Warning - this is an unashamed gloat as I finally got around to following the advice I gleaned from Rob Cosman's video and tried to make
a houndstooth dovetail :shock: (mahogany and beech is you're interested)
This is my first attempt and I am pretty chuffed with it. Next project will be a jewellery box with the corners joined using..... :-k
Alf, you'll be pleased to hear that no power tools were use on this one :wink:
Ohh, my advice when cutting dovetails is to check that your thinnest chisel will fit in the base of the tails BEFORE you make the saw cuts
