I am looking at space in the workshop, and i don't have much spare. i currently have the table saw in the middle, but seem to be moving it around a lot.
i have noted that i predominantly use it for ripping and cross cutting hardwood. I occasionally process sheet material, normally from 4x2 feet sections, ie a sheet quartered. The space issue is made worse when ripping, because to rip an 8' length i need to find 17' plus, as well as suitable infeed and outfeed support, normally having to send the outfeed through the side door. I have removed the side extension tables because they made the space issue critical.
Undoubtedly, part of the solution is to have a clear out of household stuff, but even so, the workshop remains approx 20ft x 10ft with a bench and few other machines in there.
I am wondering whether a track saw, and a dismantle-able cutting table might be an option and sell the table saw. At least the space required is confined to the table and room to walk along it, ie the saw moves not the timber.
Does anybody use the track saw for ripping hardwoods. I prefer to buy wayney edge timber and have no bandsaw. On the table saw, i have screwed an mdf straight edge on and ran it down the table saw fence. I can see how the track saw would be better. Most of wht I buy is inch, but from time to time i might need to rip 2" or 3". Is the relevant festool saw up to doing such a thing at its max capacity (model dependant). Can it cut to width as accurately as the table saw? Is it fiddly to set it up to do so? Is it capable of being used as a cabinet makers tool, or is it for site joinery only?
I have got a RAS that I can use for cross cutting requirements, mitres. So the outstanding table saw requirements all appear to be ripping based.
thoughts?
cheers
Mark
thoughts?
cheers
Mark
