I need to install two ball catches, of the kind used in cabinet doors, in through holes in a piece of soft pine.
The body of the ball catch is 12.2mm in diameter.
I only have 12mm drills (helical, brad-point and Forstner). I doubt I could find a drill bit in 12.2mm. 1/2 " might do, but anyway I would rather not buy a new bit of a size I most likely will not use again.
I tried enlarging the hole on a trial piece with a round file. This did it, but am not really happy about the results.
Any ideas on the best way (or some way other than a file...) of enlarging a hole from 12mm to 12.2mm diameter?
G.
G.
