matkinitice
- Joined
- 11 Jun 2019
- Messages
- 137
- Reaction score
- 270
This is based on the English Woodworker's plans. It was a user on here that got me to give this bench a second look. I did intend to build a Roubo but costs (both the wood and the hardware) made me re-consider.
The main goal of this build is to provide a stable bench and plenty of surface area as I find I'm working using the floor in larger projects.
I've not done this before, but my plan is to update this as I build. In terms of design this is pretty fixed but I'll work a few things out as I go such as the final height. So feel free to comment or ask questions.
£290 for the wood - I ordered slightly more than needed as I wasn't sure if I was going with a wooden vice or not (spoilers - I'm not). First task was to get this into the workshop.
The boards are 2.7m long. I'm aiming to keep as much length as possible. For now this will be the size I'm aiming for. As for width the three boards come to 645mm, but this isn't accounting for the gaps I'll have between the panels. For now these panels will remain full width (215mm) and I'll rip them down as needed. I want to limit rips and laminations on this build to save time and stress but these boards were my best choice from my local sawmill.
This is where things are at present. One of the 9x2's was crosscut and ripped to form the two smaller rails and two of the larger rails. The offcut might be used for the vice chop. The only other change was to rip two of the 6x2's down to 95mm to act as the trestle bearers. The legs (4x4) were roughly cut to size to make handling/drying easier. The same was true for the bearers - these were cut smaller than recommended from the cut list that Richard recommends but as I had modelled this in Sketchup I knew I could split the boards into two easily.
This wood is all PAR to save time. My cut list is slightly different (but relative) to what Richard recommends.
Ignore my battered prototype MFT (this will be the next workshop project to replace) but here's the hardware for the build. £276.25 (including shipping). I've had my eyes on these holdfasts for a while, plus the Benchcrafted planning stop. The biggest change for me will be the vice. This is the Axminster quick release vice guide. It's very impressive even if the finish is a bit rough, the screw and mechanism is very slick. The nails and nail punch will see plenty of use later on.
For now there will be no action - I want the wood to acclimatize for another week before starting the joinery. Behind the scenes I'll do some boring tasks which I won't share such as moving things around and getting some space to work. I can use my old bench for some of the build. My intent is to use the floor to work on the aprons.
![IMG_20221213_140512_175.jpg IMG_20221213_140512_175.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/130/130394-IMG-20221213-140512-175.jpg)
![IMG_20221217_141638_515.jpg IMG_20221217_141638_515.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/130/130396-IMG-20221217-141638-515.jpg)
![IMG_20221219_111343_027.jpg IMG_20221219_111343_027.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/130/130398-IMG-20221219-111343-027.jpg)
![IMG_20221217_115116_484.jpg IMG_20221217_115116_484.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/130/130399-IMG-20221217-115116-484.jpg)
