electrics
BHwoodworking
contact me for bespoke high end firewood!
7 Jul 2019
N Yorks
i am making a fairly small workshop and can't understand what consumer unit i need
there is going to be 3 circuits
1 - lights, within that there are going to be 3 looms(?). 2 of them only have 1 light on but the last one has 3 lights on. the lights are these
https://www.screwfix.com/p/twin-5ft-led ... 00lm/5440r
2 - other machinery/ outlets. in this there will be 8 2 gang plugs and 1 1 gang. the biggest machine it will power is https://www.screwfix.com/p/scheppach-hs ... 240v/85501 . these will only be on 1 at a time so i only really need capacity for the table saw but would like a bit more.
3 - this will have 1 1 gang socket on. but it will have the dust extractor on. i'm going to get this one
https://www.axminster.co.uk/axminster-c ... tor-105845
any help would be highly apreaciated.
many thanks in advance. :D
Steliz
Camberwell Carrot
11 Dec 2017
Hungary
As long as you didn't switch on your machines simultaneously you could have them all on one breaker in terms of load. I'm not suggesting you do that.
I personally wouldn't bother having an individual circuit for the dust extractor for the above reason but, if you are going for a third circuit, then split up the sockets more evenly. I've assumed your on single phase.
DBT85
19 Dec 2015
Pershore, Worcester
Honestly from what you've said I'd say get an electrician in. It needs to be signed off anyway so you are best to get them to spec what you need. Some are happier than others to let you do different levels of the work but anything to do with a CU if you do it yourself few if any will sign off on it.
With that dust extractor there's no need for its own circuit as its only 1.5kw.
BHwoodworking
7 Jul 2019
N Yorks
ive got a mate thats a sparky and he'll give me mates rates. so i'm gonna get him to do it
gmgmgm
29 Aug 2013
Wiltshire
Always handy to have a few spare slots - e.g. you can add a wifi meter / master on/off which takes up 2 DIN slots at a later date.
I've set mine up so there is one circuit for "always-on" e.g. chargers, Anglepoise, dust extraction; and a second circuit (with a big on/off rotary switch) for the "dangerous machinery" e.g. saws. Reassuring to have this when there are children about.
