Electrical switch fixing screw thread
RogerS
20 Feb 2004
In the eternally wet North
Does anyone know where I can get some nuts from that fit the screws used to fix sockets/switches to the pattresses? The thread is larger than M3 but not as large as M4...if there was such a thing as M3.5 then that would probably be it.
But....I have a sneaky feeling that the thread is non-metric.
Many thanks
Roger
johnelliott
16 Apr 2003
Near Swindon, Wiltshire
It's actually the nuts that Roger wants. I reckon the best bet would be to get an M3.5 tap (if you can) and run it through some M3 nuts
jasonB
26 Nov 2004
Surrey
M3.5 nuts here in small quantities.
If you want to use johns method I can point you in the right direction for Taps.
Jason
DaveL
19 Oct 2002
Sudbury, Suffolk
I was trying to point out that Roger was indeed looking for M3.5 which he seemed doubtful of its use. I had no idea where to get the nuts just the size he needed. Sorry if I miss lead anyone.
Midnight
11 Oct 2003
Scotland
ummmmm.......actually they're not M3.5... I think you'll find they're closer to 3BA...
good auld fasioned British Standards... Ahem....
DaveL
19 Oct 2002
Sudbury, Suffolk
Mike,
They used to be 4BA, M3.5 is very close. Too close if you mix old and new fittings/boxes the screws just go in and then get tight, one quick twist of the wrist will fix that as the thread strips. :roll:
CHJ
31 Dec 2004
Cotswolds UK
I think you will find that old ones (up until the 60's) were 6BA, latest incarnation is M3.5, hence why replacement fittings using new supplied screws in old patrices result in messed up/stripped/jambed screws.
Most electrical supply factors will have M3.5 taps for 'adjusting' the slightly smaller 6BA hole in old patrices to suit.
