Quantcast
Electrical Die grinder 6mm capacity
Aden30mm
25 May 2012
Lincolnshire
I've recently been using a dremmel type machine with a 1/8 shaft Tungsten Carbide Burrs. I have been quite impressed with the way its moved stock away from some yew.
Ramping this up I wonder if using a electric straight die grinder with a 6mm shaft tungsten carbide burr would allow for faster stock removal. So the question is have any members of the forum used this medium, or have experience of wood (hardwood) stock removal.
Regards
Aden
dickm
25 Oct 2004
North of Aberdeen
Did try briefly using the body of one of the old detachable Bosch routers in that way, but didn't find it very effective. Maybe with practice......
If you are brave, of course, there are the Arbotech blades for an angle grinder, which will take off stock (and probably fingers. toes or other body parts) at a phenomenal rate.
Turbo
14 Jan 2018
Sunny Fermanagh
I use a die grinder on metal & they can't half shift stuff with a good cutter but I've never tried it on wood. I think the problem you might have is the cutters clogging. You could try using cutters for aluminium as they are designed not to clog.
ED65
3 Dec 2015
What's the max speed on your mini drill Aden?
Aden30mm
25 May 2012
Lincolnshire
Went for it with a cheap straight 6mm die grinder, a Katsu (no load speed of 24,000) for just over £20 plus a set of Tungsten Carbide Burrs (Drillpro).
Pretty impressed with the roughing out of some yew No clogging up of the burrs, fast removal of stock to a point where a rasp works. Even better result with laburnum. One take away, need to have respiratory protection, I use a half mask with a suitable replacement filters.
ED65 speed on mini grinder is NLS 25,000.
All in all I'm pleased with this set up all for less than £35, and the Katsu grinder seem to be a robust unit, but only time will tell.
SVB
2 Jul 2005
Nailsworth, Glos
\I use a katsu with the saburr carbide cutters. Great tool although too fast for the larger 30mm ish dia cylinder type cutters as vibration is crazy.
Paul200
12 Feb 2015
SW Scotland
Just off to hospital for a consultation so can't go into detail but check out 'bonsai carving' on your search engine. Bonsai artists have been doing it for years - usually with Makita die grinders and carbide burrs. I've personally used an Arbortech blade to shape jewellery box lids too - once you get the hang of it it's very easy.
Paul
