Edge joint, one inch birch ply?
No I wouldn’t l be confident with three by one softwood, especially not at 800 mil high. My saw horses are 450 mil high and I used 1 1/2 x 2 1/2
Perhaps a sketch might be useful please Dave
Edit, 4 x 2 equals 8 square inches 3 x 1 is three that’s quite a reduction!
Well you’ve got me there Deadeye, and I thought I was being my normal smarmy self.
Always good to get a bystanders point of view, come on, lay it on the line, I can take it. Tell me, warts and all.
All I asked was how I might join two pieces of 1 inch ply. I noted, 50lb load max?
I think that with a leg of 800mm or so and a foot of 450mm or so, whether making them from solid timber or ply, I'd want some kind of bracket/gusset to strengthen the 'ankle' joint to resist racking forces. Why does the leg need a foot at all (assuming this is the leg of a saw horse/trestle-type thingy)?
Cheers, W2S
Cheers, W2S
A 3" cross member takes care of that. Foot needed (as with people) to stop it / us tippling over? See the sketch in the link I posted?
I’ve actually made a pair of these. I used oak as I had some. They work really well. If you’re going to make them from ply, I’m guessing you’re asking about joining the foot to the bottom of the leg. I used doweled mortice & tenons, but in ply a few biscuits should do it. You may need to beef up the two rails to resist racking.
I think you have fallen into the trap that so many do, in that you think the question is easy as you don’t understand all the permutations and neither do we, so we ask.
If someone said “how do I join these two sheets of 2mm aluminium together?”, answers may vary from rivets and bolts through welding to adhesives and crimping, none or all of which may be appropriate depending on if those sheets were the stressed skin of a combat jet or a plant pot.
Aidan
The strength required from the joint will depend upon how you plan to use the horses. If using like a heavy duty saw horse then Custards design has a proven track record. You have said they are light duty and a max load of 50kg but it depends on how that load is applied and how it is cycled as to how stressed that joint will be.
Any form of joint that you cut will be removing material and potentially weakening both members. Using ply to form the joint either as the tenon or as a loose tenon means that only 50% of the fibres will be giving you any strength. I would also suggest that even at 3 inches wide dependant upon the racking you could get problems.
Simplest approach with either solid or with 1 inch ply would be dowels/domino with additional bracing. You could achieve this with external gussets of 6mm ply, gussets of 1inch ply which fit into the thickness of the frame (advantage of ply is that you should get a good joint just gluing in as you will get edge grain to edge grain) or achieve the same effect by tapering the uprights so it is 3 inches wide at the top and say 6 inches wide at the foot
Ian
I'm afraid I didn't find the sketch easy to interpret - I saw a horizontal piece (foot?) and a central vertical piece (leg?) coming vertically upwards from it and I thought the joint in question was the one between these two components.
Ian
No, I said 50 pounds, not Kg. In a largely stable usage.
I can't see how dominoes would be as close, strength wise, as a through tenon.
Tapered ply legs would be a good idea.
I have decided on solid wood, after this threads advice.
I referred to the cross piece some 10" up from the foot.
Please can we close this thread now, I've decided on a design.
