I would like to bend an 8mm brass rod but am not really sure what sort of tool I'd need.
Does anyone know the easiest cheapest option?
I was thinking I could perhaps drill then use a tap and die set to install two steel bolts/rods into a section of metal then fit it into my bench vice, use a pipe as leverage to bend the rod between the steel pieces.
If there's something cheapish I could buy I'd be happy to save the time of building something. If steel is easier I can use that.
Thanks.
Thanks.
