I've just bought a secondhand sony PRS-505 from ebay and find it really simple to use. I buy books from WHSmith - cheaper than waterstones but a lousy web page.
A word of warning if you buy a secondhand one (any make) where the original owner has ever put a DRM (adobe epub protected) book on it. You will not be able to download any other DRM protected books to that reader without factory resetting it and losing all existing DRM....so read the books before buying your own!. This is because the ereader is locked to the owners adobe username/account.
FYI to do a reset on the PRS-505....
with the ebook off, use a paperclip in the reset hole for 10secs.
power on the ebook and hold down the bookmark button and the volume up keys for approx 25 seconds...then the warning menu will appear and prompt you that you are about to lose the DRM. Say yes (if you are sure!) and then when you try to use your own adobe DRM account to push a book the ereader will then register itself to you.
EDITED as sony provided this method using the library reader app...
In regards to the issue, I can confirm that you will need to de-authorise the Reader and then re-authorise it using the same details you used to register with Adobe Digital Editions.
You will need to:
- Open up the Reader Library and highlight the E-Reader icon on the left hand side.
- Once highlighted, press CTRL+SHIFT+D (tap D a few times), this will de-authorise the Reader.
- Unplug Reader, go into SETTINGS then ABOUT to make sure the Reader is now de-authorised.
You can now re-authorise the Reader:
- Plug the Reader back into the computer.
- Drag and drop the purchased book onto the Reader icon on the left hand side.
- You will now be asked to authorise the Reader, be sure to enter in the same Adobe ID details as you did to register with Digital Editions.
- Go to STATUS, and it should say authorisation complete.
Dave
PS i bought the Sony as the kindle3 would not ship in time for holiday and I like the idea of the £149 with wifi and web browser. Amazon kindle book prices appear better than epub ones if you re happy to be locked in.
