I need your advice please.
I need to add localised dust extraction to two bandsaws sited together in a workshop.
One's an elektra beckum 250, the other a slightly larger startrite, so 10" -12" size machines.
My impression is that high volume low pressure extractors / chip collectors aren't well suited to bandsaws and I'd be better off with a high vacuum steel drum type - something like the axy trade / numatic nd750 machine maybe.
Could the bandsaw users here please share what does and does not work for you.
The two bandsaws will be in use at the same time so I need two extractors or one larger one that's got enough airflow for both. Noise is always an issue. For that reason the yellow / green record power things are out. Positively offensive !
