- Joined
- 7 Aug 2003
- Messages
- 7,612
- Reaction score
- 1,030
Nearing the completion of phase 1 (well first room) of our loft conversion and it's time to sort out the wall finish. Two sides are block, the remaining two sides are rafters with the usual insulation stuffed between them. Was going to go along the traditional route with plasterboard and plaster. Then thought about drylining and paint. I know the 12mm stuff is tapered. Canny find a picture of the stuff but am I right in assuming it's tapered on all 4 sides? And how do you handle the joints if you have to cut a sheet and have no taper? Presume it's reasonably simple to join the tapered edges with scrim tape, bonding (or similar) and bit of sanding?
Anybody familiar with this?
TIA
Rgds
Noel
TIA
Rgds
Noel
