Benchwayze
In my loft there is a length of cable that goes across the floor, from one bedroom rose to another. I know the pesky thing is there, but I regularly foul it when I am up there. To get rid of this trip hazard, I want to cut the cable and drop in a spare length, (About 2.5 metres) so I can raise it overhead in the roof 'A' frame. I plan to 'cable-clip' the new length up one side of the 'A' frame, and down the other, joining each end to one of the new ends where I have cut through. I hope someone can envisage this.
I think it's possible, but I need to know what to use to connect the new length of cable, safely, between the two ends of the existing cable, after I've cut through it. (Yes I am isolating the circuits first. ) I hope someone who knows can envisage what I mean. Can someone please advise as to whether or not I can use two of those circular, Bakelite junction boxes to make safe connections?
(Or would some of that nylon/plastic strip with the screw connectors suffice, if it is insulated afterwards? I doubt it of course, as that seems like a lash-up.)
I'm not a qualified sparky, but I know when a connection is good, and I know which is pos, neg and earth.,
I also believe I should put green and yellow sheathing on the earth wires.
Thanks in Anticipation
