dennisk
Silly question, but could I use a Oneway Live Center for a drive center if I put a pin through the hole used to lock the shaft to the bearing body?
But you'd still need the pin - remember it's a live centre.monkeybiter":2d3le0be said:It certainly looks like it if you have or construct a drive adapter between the threaded shaft of the live centre and the workpiece. Or you could just drill the workpiece 5/8" and screw the threaded part straight in.
I quite agree - no point at all, but I have done this in the tailstock, which is what they intend those adapters for.monkeybiter":2d3le0be said:I notice from their website they sell lots of thread adapters so you could even use it to mount a chuck if you felt that way inclined, but then what would be the point?
You sort of beat me to it - it works very well, as long as you put the live centre in the tailstockmonkeybiter":2d3le0be said:I also noticed that they sell a 'Safe Driver' which is a sprung drive centre without spurs or teeth, allowing slippage when caught, so it might work without an adapter if you tighten the tailstock and take light cuts.
I'd probably hove got a different drive centre if I hadn't splashed out on the Oneway live centre, but as they match perfectly it was a (n expensive) no brainer.Jonzjob":32duztz0 said:Pete, that drive looks a bit like the Steb center without the teeth. I have both the drive and the live steb centers and I find them good
http://www.toolpost.co.uk/pages/Chucks_ ... ntres.html
I too would forget trying to use a live center for driving when there are so much better alternatives. I also have a couple of ring drive centers. They are like the Safe Driver, but a solid bit of metal, no moving parts. They have given really good service for a fraction of the cost of a safe driver, or a steb for that matter.
