Dremel and station help for possible doing joints?
manxnorton
29 Jun 2016
Newcastle
Hello all,
Me again!! Haha!
As you know I struggle using my tiny brain and I'm sorry if you don't understand what I'm talking about.
I've got the dremel (think 3000) and base stn.
In my mind it might be used on the stand to sort out the joints..like a router etc.
If anyone has an idea and help for attachment etc I'll be chuffed to bits.
My problem (apart thinking!) is getting everything exact!!
There be links on the net, but I struggle..
Trying to type in what I mean now!!
Fingers X'd I might find it!
Thx all
ATB
Bri
like this one.
    116.9 KB
Hi Bri, as I mentioned in the other thread, the dremel attachments are often pretty rubbish.
The other thing to mention is the dremel only has small bits and is limited in power. You'd be there all day chopping out wood with a dremel.
I have the exact same setup and I must warn you to check it when you use it for accuracy. When I'm using mine as a vertical drill press it is not perfectly vertical, it's a couple of degrees off straight and it gets worse as you lower the Dremel. (See my post about it here: sack-of-rubbish-dremel-workstation-need-help-t98479.html)
Also you will find there's some movement, or wobble, when you're using it as a router so once again be careful if accuracy is something you're after.
I'm afraid to tell you it's cheap rubbish and I wish I'd never bought mine.
Great advice guys!
The more I think on it....(takes some time!!) haha! I wish I never bought the stand..the dremel is good for small chores but not anything else...
Thx I'm made my mind up...
Btw my pal that has our workshops just told me I might got one of a old band saw in there!!! Forgot about it!! Lol
If it's there and fit he going to send it or I'll get when I'm down for my break out.
What else I have is a mystery!!!
Back to square one...
Thx a lot
ATB
Bri
