Dovetail Plane
ac445ab
7 Jul 2007
Naples-Italy
I just finished restoring this German old dovetail plane. It cuts very well and produces a clean result.
The first pic is the plane as came to me from ebay.
This has an adjustable depth stop also, a feature not so common for dovetail planes but very useful.
Here, its story:
http://woodworkingbyhand2.blogspot.it/2 ... ne_27.html
Ciao,
Giuliano :D
I really like that Giulano. An unusual old tool, found by someone with the ability to research it properly and do a wonderful restoration back to working order.
Have you had a chance to try it working cross-grain yet? It looks like it would work well, for shelf ends and suchlike, with its skewed blade and nicker.
WOW....Giuliano
That was my remark...out loud...as I scrolled from the first picture down.
That is a superbly crafted and sensitive restoration...back to a working tool which just about sums up my idea of the perfect job!
You do however realise don't you that I am now on yet another woodie quest and I hold you totally responsible my friend! :mrgreen:
Superb work as usual! =D> =D> =D>
Jimi
I tried today. Clean cut cross-grain too :wink:
Thanks for appreciating my job.
Ciao
Giuliano :D
Jimi
Then, do not look at my next posts. I refuse any responsibility :mrgreen:
Giuliano :D
Ok...that's it! 8)
Before I make my little brass and steel mitre plane..I will be making a pair of these.
I love sliding dovetails...very elegant and this is an equally fine solution to creating them.
I like Derek's approach too....I missed this so thanks goes to BB for reminding me.
Cheers Giuliano....something to keep me busy in my "retirement!" :mrgreen:
Jimi
very cool. Do you start the female part with a straight rabbet or bare wood?
Pedder
Edit: OK, I should have followed the link:
Great job, Giulano!
But tell me: how do you tackle the thing with the tapered joint? Normally, the dovetail groove is slightly tapered to give a tight fit. Do ou taper the male part instead or do you cut a tapered groove with your guide fitted to lines not parallel to each other?
Regards, Philipp
Philipp":4yirwe8r said:
Great job, Giulano!
Regards, Philipp
Ciao Philipp,
For a tapered dovetail joint I would trace the lines on the groove not parallel (the only limit is that the minimal dovetail width must be inferior to the blade width).
For the male, you can first cut it straight, so taper to not parallel lines with few other plane shots (following pics).
Giuliano :D
jimi43":5qmlisvs said:
Hi Giuliano
Just a quick question. What angle is the sole set at from the side on the male one?
Jim
It's 78° and it depends from the male plane.
Giuliano
ac445ab":1g7gqdpu said:
jimi43":1g7gqdpu said:
Hi Giuliano
Jim
Giuliano
Actually Giuliano...I was just being stupid! :oops:
After having read through your blog and Derek's again...it all became clear...silly me!
Thanks for the confirmation...
Jim
I'm thinking over designs for a bookcase at the moment, and feeling slightly tempted to use it as an excuse to need to make a plane of this sort ... I hope no one minds me digging up this old thread.
Lots of questions come to my mind. Firstly, 78 degrees... That would seem to cut the dovetail sides at 12 degrees, which seems quite steep (1 in 6 being about 8 degrees at my rough mental reckoning) - are sliding dovetails normally cut at a steeper angle ?
A couple of things relating to the skew of the cutter too; firstly, if I'm not mistaken the skew is the opposite way around to a normal, right handed skew rebate plane - is there a reason for that ? Normally it is skewed so as to pull the fence up against the workpiece, I thought. My second thought on skew, is is it actually needed ? Since the sole is angled, in combination with the bedding angle of the plane, won't this naturally give a cut skewed at about the same angle as the dovetail's slope ?
Hi Tony,
sorry, only now I saw your reply....
The 78° angle was for matching the male plane. This angle is variable. ECE dovetail planes have a 80,5°, the Ulmia ones 73°
http://www.ulmia.de/English/Ulmia-Hobel ... nfacheisen
http://www.fine-tools.com/divhob.htm
But I don't know why these differences.
For the skewed blade, the left skew orientation is for pushing the shaves in the opposite direction of the wooden guide.
If I understood well your second question (I am a beginner student of English), I don't believe the effect of angled sole was the same as the skewed blade.
Ah, so it is skewed opposite to the way I expected. Looking at your photo helps; I guess it would reduce the risk of undercutting the guide and making a loose joint.
Thanks for that Giuliano.
