Giff
Does anyone know the theory using Sippo or Beech Domino rods. If the frame is glued, eg window, then painted and sealed is it necessary to use Sippo tennons ? They are nearly twice as much. Geoff
srp":2l2e9lq6 said:A frame will (99% of the time) fail because of water ingress at the joints first. Beech is not a durable wood by any means, so the standard doms will rot out in no time once they are wet, long before the surrounding timber. It's not difficult to make your own from redwood or iroko, though they do need to be accurate. I made some for a bit of marine work from iroko - it doesn't take long to plane up some strips and snip them off on the bandsaw.
Register today and take advantage of membership benefits.
