thecoder
I have heard quite abit about dominos on this site, so had a look at the prices, when I came round from the shock, I wondered if those folks that had bought them thought they were a worthwhile investment ?
clk230":19n3msbh said:unless your a pro earning money from wood then their a total luxury .
Speak for yourself Steve, I only managed decadesSteve Maskery":kxzey93z said:Nobody needs a Domino. We managed for centuries without...
Lord Kitchener":3fmxlz8x said:I have one and it's the first time I've been a bit disappointed with a Festool product, it simply isn't as accurate as I expected. I still use it, but only in situations where I don't need things to line up perfectly.
Lord Kitchener":3oc5bzdp said:I have one and it's the first time I've been a bit disappointed with a Festool product, it simply isn't as accurate as I expected. I still use it, but only in situations where I don't need things to line up perfectly.
JonnyD":xpsczl9l said:Lord Kitchener":xpsczl9l said:I have one and it's the first time I've been a bit disappointed with a Festool product, it simply isn't as accurate as I expected. I still use it, but only in situations where I don't need things to line up perfectly.
Probably down to your technique i would think, the machine itself is extremely accuarate.
Oryxdesign":2gy28o8m said:Festool will have it collected from wherever is convenient, check and teat the tool and then send it back to wherever is convenient. Seems mad not to get it checked and find out for sure.
Lord Kitchener":1av09jbu said:Oryxdesign":1av09jbu said:Festool will have it collected from wherever is convenient, check and teat the tool and then send it back to wherever is convenient. Seems mad not to get it checked and find out for sure.
If you are referring to me then thanks for the info (I already knew, I've been dealing with Festool for years) and I expect that I will get around to doing that eventually. But I do already know that as is it is below my accuracy/repeatability requirements, so they may well opt to change it or alter it, but I won't be finding out anything for sure, I already know.
Oryxdesign":3fv3mv4w said:Lord Kitchener":3fv3mv4w said:Oryxdesign":3fv3mv4w said:Festool will have it collected from wherever is convenient, check and teat the tool and then send it back to wherever is convenient. Seems mad not to get it checked and find out for sure.
Which part of the tool do you find inaccurate?
Register today and take advantage of membership benefits.
