Dog Door
SteveF
16 Sep 2013
Maidstone
i have been given the challenge of building dog door
we have a cheap one but the rubber swing door will never seal the hole
plan is 2 doors
one on outside that shuts against outer door with magnets at bottom and seal around the edge with hole in it ( just a frame tbh)
other door opens in but closes against outer frame
does this make sense
i cant weld btw
Steve
If the dog is outside, how does it open the door to get in?
If the dog is inside, how does it open the door to get out?
Assuming both doors are closed of course.
xy
i knew i could not explain well
outside is a frame on hinge fixed to door
inside is acrylic attached to frame with another hinge
dog goes out and pushes acrylic and frame
dog comes in...the frame stays still.... the acrylic swings in
so any ideas on the build ?
please
door is usual white plastic
already has hole cut for **** dog door
i think maybe piano hing
earth magnets
sticky back seal
but what make out of ?
I can rivet
i can cut wood
I can't weld
but would pay for someone to weld if best option
Steve
How about investing in a decent manufactured one like Stawells, and adding rare earth magnets or strip magnets if you want more closing power.
Phil
2 dogs ......big dogs
I not getting up half way thru the nite
I wouldn't dare try climbing thru the dog door....let alone worry about an intruder getting eaten
and I have orders from boss lady
I just got to work out how to make it
I am thinking aluminium angle , hinges , magnets, rivets and a big headache
You need something like this maybe ?
or this
:D
wood cut and
frame built
hinge added
and some ali angle
    102.8 KB
not really working
so that will go on the fire
another bit of wood
and start again
works much better
    146.6 KB
    150 KB
    76 KB
