matt scarlett
I've tried so hard to find sheets of HDF, and google is showing me nothing. I'm beginning to believe that it doesn't actually exist. Can anyone give me any pointers please?
skipdiver":q0nj3xj3 said:http://www.pbplywood.co.uk/high-density-mdf-cnc-routering-grade/
Our transmission line cabinets are hand crafted from 18mm Hdf
ED65":31j8xrxm said:Hardboard, what our American cousins insist on referring to as masonite, is an HDF material. In the past hardboard was commonly available in thicknesses other than the usual 1/8" and 1/4", up to a maximum of 1/2" IIRC. At least that's according to the books, I've never seen any in the flesh thicker than 1/4" or 6mm.
High-density MDF is not the same as an HDF product as it used to be defined, but that may not matter. Density may be all that's considered important, that said a great many speakers are made from regular MDF. It's possible that "HDF" is just the new selling point rather than actually being of any real importance.
ED65":r1wz35lb said:Hardboard, what our American cousins insist on referring to as masonite, is an HDF material. In the past hardboard was commonly available in thicknesses other than the usual 1/8" and 1/4", up to a maximum of 1/2" IIRC. At least that's according to the books, I've never seen any in the flesh thicker than 1/4" or 6mm.
oakmitre":22cvjb9m said:My local Floors2Go branch would put it outside for people to take away. It came on the bottom of the pallets between the goods and the pallet itself. The density between sheets would vary, some of them were very hard.
I'm not sure that matters too much if you are freeloading HDF from palletsmatt scarlett":2qvwtgmn said:oakmitre":2qvwtgmn said:My local Floors2Go branch would put it outside for people to take away. It came on the bottom of the pallets between the goods and the pallet itself. The density between sheets would vary, some of them were very hard.
Floors2go don't seem to have the best of reputation :shock:
https://www.google.co.uk/search?q=Floor ... e&ie=UTF-8
Bodgers":3userp32 said:I'm not sure that matters too much if you are freeloading HDF from palletsmatt scarlett":3userp32 said:oakmitre":3userp32 said:My local Floors2Go branch would put it outside for people to take away. It came on the bottom of the pallets between the goods and the pallet itself. The density between sheets would vary, some of them were very hard.
Sent from my MI 3W using Tapatalk
oakmitre":28qa8jq2 said:I suspect if you wanted it you could speak to the manager of the store - it costs them to remove these sheets - they were glad to have me take it away.
I have heard of this stuff referred to as 'flooring hardboard' in the past.
Anyway I have cut some B&Q MDF to the same size as the HDF - the HDF is thinner but still heavier. Photo attached.
