hi all,
I'm working on a small project that requires a bit of trim/template routing.
I have a fairly cheap but fairly powerful router and an old table and I'm in the process of making a simple DIY router table out of.
Everything was going well - holes drilled, and router mounted.
And then I noticed a problem....the router does not have enough depth to clear the top of the table. With a router bit installed it probably only a CM above the table top. For me todo anything useful it needs to be higher.
Can anyone recommend an extender....or do I simply need a better router?
